83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Can't find precast concrete wall tees in Revit Structure 2012
Mon, Nov 21, 2011 at 7:24:56 AM | Can't find precast concrete wall tees in Revit Structure 2012
danwhitlock
I am trying to build a model of a building using precast concrete double tees. The only families I can find in Revit Structure 2012 are listed in structural framing and the tees are listed as being for roof or floor decks. I have figured out how to rotate them to a vertical orientation, but they are still not recognized as walls, so I can't add doors or windows to them. I also have not figured out how to trim a tee at the end of a wall, which you usually have to do to make the walls match up at the corners of a precast building. Any help would be gratly appreciated.
Mon, Nov 21, 2011 at 7:39:09 AM | Can't find precast concrete wall tees in Revit Structure 2012
For vertical double tees, I would stiil start with walls and add face based families that define the tees, legs and joints.  That family can be use for counts and dimensioning but let the walls function for windows, doors and corners.
Tue, Nov 22, 2011 at 3:25:49 PM | Can't find precast concrete wall tees in Revit Structure 2012
danwhitlock
Ok, now I get to show what I don't know about Revit. What is a face based family? Do they already exist in Revit or is this something you have to build your self? If so how do I get started. Thanks
Wed, Nov 23, 2011 at 6:29:14 AM | Can't find precast concrete wall tees in Revit Structure 2012
You will have to create the family.  A face based family will be hosted on any face of any object - in this case a wall face.  It would be a simple extrusion, the shape of the tee legs only and should be parametric so that you can set its length (height for vertical).
BTW - What I am describing is purely architectural elements.  They would not have any structural properties.
Thu, Mar 15, 2012 at 9:53:48 AM | Can't find precast concrete wall tees in Revit Structure 2012
DusterSlant6
DusterSlant6 Avatar
3 Stars: 1 Votes
The method I used was to make a profile and use it as a vertical wall sweep.  Then join the sweep to the wall.  worked great.
Precast Concrete Panels
Fri, Mar 31, 2017 at 12:28:40 PM
13
Attaching double Tees to a sloped floor
Thu, Aug 13, 2009 at 1:23:45 PM
Structure layer of furring wall cleaning up with structure of concrete wall.
Mon, Nov 3, 2008 at 9:48:01 AM
Materials Don't Appear in Rendering
Thu, May 21, 2009 at 12:56:30 PM
2 Families for Concrete structures
Wed, Dec 21, 2022 at 1:09:07 AM
Page generation time: 3.2851
