145 Users Online (143 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
Mon, Nov 21, 2011 at 1:23:21 AM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
CRB14
Hi there,
Today I tried building a topography using a 2D file (with numbers but no contours) sent by a client.  (Please note, I've never built topography before, hence the questions...)
Basically I created a topo surface in 5m increments. As you can see in the attachment, it is lacking enough info to give the topography enough form etc. I need to draw contours at 1m increments I think.
Question 1) I want to show the contour lines I draw when I make the topography, how do I 'turn these on'?
Question 2) Is there a way to colour the contour lines? i.e. Red for 5m increments, black for 1m?
Any comments/feedback etc on the way I've built this, please feel free...
Thank you!
Mon, Nov 21, 2011 at 1:42:50 AM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
CRB14
I can never get the links to work for my images....tried jpeg and png...any ideas?? otherwise email me charlottebowie@gmail.com and I'll flick images to you..
Edited on: Mon, Nov 21, 2011 at 1:48:27 AM
Edited on: Mon, Nov 21, 2011 at 1:48:45 AM
Edited on: Mon, Nov 21, 2011 at 2:35:30 AM
Mon, Nov 21, 2011 at 3:35:25 AM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
4 Stars: 203 Votes
If you search you will find: http://www.revitcity.com/forums.php?action=viewthread&thread_id=10947
Mon, Nov 21, 2011 at 1:05:35 PM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
CRB14
Thank you for that link - I'd read it previously and not been able to find the settings > site settings tab anywhere.....please help! thank you
Mon, Nov 21, 2011 at 1:25:52 PM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
4 Stars: 203 Votes
I forgot to ask what Revit version you use but take a look at these images
Mon, Nov 21, 2011 at 2:25:16 PM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
CRB14
Hey - I'm using Revit 2011 - found the spot to turn on primary & secondary contour lines....but they still are not showing. Have tried viewing in different scales etc....unfortunately I can't screen shot and send to you cos I have difficulty in attaching images in these forums.....
Mon, Nov 21, 2011 at 2:58:53 PM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
They also have to be turned on in VG.
Mon, Nov 21, 2011 at 3:28:44 PM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
CRB14
VG = Visibility graphics? I'm pretty sure I've ticked all the boxes there.....but still not showing on the 3D model.....thank you so much for your help!
Charlotte
Mon, Nov 21, 2011 at 5:02:19 PM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
CRB14
Another question........We are working on a 1:100 scale topographical model. We have mistakenly plotted our contour lines at 1000m elevations rather than 1m elevations which has created a lunar landscape. How can we downscale the elevations to 1m using this model??
Any help appreciated! Thank you
Tue, Nov 22, 2011 at 6:07:38 AM | A Whole Lot of TOPOGRAPHY & CONTOUR LINE questions...
Look again at the image Typhoon posted - your answer is there.
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:47 PM
Topography points Crash in Revit 2013
Wed, Oct 31, 2012 at 4:34:48 AM
toposurface
Tue, Sep 5, 2006 at 6:03:13 AM
Can you darken every 5' contour line?
Mon, Aug 15, 2011 at 9:23:35 AM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:53 PM
Page generation time: 2.3098
