73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> BUILDING ENVELOPE
Fri, Nov 18, 2011 at 9:00:13 AM | BUILDING ENVELOPE
michB
How do I create a plan that just shows the building envelope in revit 2012?
Fri, Nov 18, 2011 at 9:11:20 AM | BUILDING ENVELOPE
jterrell
3 Stars: 5 Votes
Filters
Fri, Nov 18, 2011 at 9:22:33 AM | BUILDING ENVELOPE
Filters won't do a thing for you because there is nothing to filter.  We put our exterior walls/doors/windows and the floors/roof in an exterior shell workset.  Then you only turn on that workset.
Fri, Nov 18, 2011 at 10:00:35 AM | BUILDING ENVELOPE
michB
I am the only person who works on these projects.  Is worksharing-worksets the only way or the appropriate way when in future more staff could be working off a central file?
Fri, Nov 18, 2011 at 10:09:27 AM | BUILDING ENVELOPE
We have found that even on single user projects, we like to turn on worksharing because of the advantages it gives us.
If you can somehow assign these elements to a selection set that can filter them..... but I have not done that and I don't even want to try when it is so much easier to use worksets.
Fri, Nov 18, 2011 at 1:58:21 PM | BUILDING ENVELOPE
michB
I have figured out the whole Central file set up with worksets etc. however not sure how this will be helpful in the sense that when I create the "building envelope" plan using the one workset required it also changes the first floor plan showing only what workset I've chosen to be visible....It changes all plans set up?  How do I keep different views withing the same project/workset
Buildable envelope using mass
Mon, Aug 20, 2007 at 3:54:50 PM
Generic planes to study building envelope zone limits
Mon, Jun 8, 2009 at 12:13:43 PM
Curving a Truss around an irregular mass
Sat, Feb 28, 2009 at 2:02:19 PM
Curving a Truss to align with a mass
Sat, Feb 28, 2009 at 1:57:50 PM
dividing project and linking files : structure, interior/envelope walls
Wed, Apr 6, 2005 at 6:22:49 PM
Page generation time: 1.1553
