144 Users Online (143 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Training >> Dimension aligned
Thu, Nov 17, 2011 at 8:59:32 AM | Dimension aligned
viktorik
I think I am not the first with that question , but how to make a aligned bimension between 2 angular walls , dimesion must be aligned to one of the wall or only to the points , or to make a line that intersects all the walls and align dimesnions to that line, but if i will delete that line , the dimension line must stay, a kind of nonasociated dimension, only through points.a dimension that is aligned only to selected points, like in autocad...  detail line helps but how to make it invisible ...
Thu, Nov 17, 2011 at 9:10:56 AM | Dimension aligned
A couple of tricks:
  1. Use your tab key to select a point instead of a line/face.  The point must be an intersection or the end of a line.
  2. Draw a temporary line perpindicular to what you are dimensioning.  Start your aligned dimension using that line then dimension both ways and complete the dimension.  Delete the line.
Thu, Nov 17, 2011 at 9:38:21 AM | Dimension aligned
viktorik
but when i delete the line the dimensions are deleted too, yes with tab key I select the intersections
Thu, Nov 17, 2011 at 9:49:27 AM | Dimension aligned
One dimension - not two.... A continuous dimension.
You should use continuous dimesions whever possible.
How to make an aligned dimension?
Wed, Dec 11, 2013 at 5:19:54 AM
Aligned dimensions on non-orthogonal walls
Sun, Jun 11, 2006 at 8:16:11 PM
Aligned dimensions
Wed, Apr 12, 2006 at 3:22:31 PM
Using Aligned dimension to manipulate a square to perfect specifications????????
Mon, Sep 23, 2013 at 8:00:53 AM
DIMENSION QUESTION
Wed, May 9, 2007 at 9:35:52 PM
Page generation time: 17.1251
