61 Users Online (59 Members):
Forums >> General Discussion >> Revit Project Management >> revit 2010 edit families
2 Posts No Rating |
Hi to everybody. I'm Francesca a new member and I write from Italy. I just started to use Revit 2010 and I need some advices! :-) How can I edit the dimensions such as height of trees that i downloaded? And moreover, I succeded in changhing the materials in the family edit tools ( in object style) but when i transfer the tree family in the project I can't see the materials, neither the colours.... can someone help me??? thanks!
Are those "trees" imported objects like CAD files? If so I believe you don't have any dimensions, what you must do is a "Scale" of that obj. with the Height you want.
About "Materials" remember... PROJECT RULES..... before you load that family into project go to materials and see the "names" you have in there, then, in project, do the same (go to materials) and check if those "names" are corrects like you want, if not, change like you want.
Also, if you search in our "Forum" page for "Sketchup" you will see lots of threads about this same issue.
Hope this help
2 Posts No Rating |
thank you very much! :-)
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
You can find more trees in 3D warehouse, great source of stuff, changing materials is limited.
Edit Default Families |
Sun, Jan 24, 2010 at 8:23:42 AM
2009 families I created don't work right in 2010 |
Fri, Oct 2, 2009 at 12:01:29 PM
Edit Families Within A Project |
Thu, May 1, 2008 at 11:48:38 PM
Revit 2010 and Revit 2009 families error |
Mon, Sep 21, 2009 at 1:35:48 PM
Rendering Families in Revit 2010 |
Mon, Jul 19, 2010 at 5:39:45 AM
Members: | 2026282 | Objects: | 22993 | Forum Posts: | 152208 | Job Listings: | 3 |
