130 Users Online (128 Members):
Forums >> Revit Building >> Technical Support >> Concrete panel
We wish to cut concrete panels and have the steel visable. Detailing many of them at the moment and wish to make a few generic ones. We tried making them various things I.E casework, structural columns etc. The hatches get all screwed up. Any easy solution?
do you want to use them as walls or just as an external family? you can create it as a generic model, extruded with parameters to control width and height, thickness... use extrusion for the steel pocking out, have a look at Mr. Spot's tutorial for nested array, will give you an idea
Good luck
HTH
I would try and create the rebars as a sweep. Are you looking at a grid pattern or ? You could add the sweeps within the wall editor if it's the same in each panel.
Dimensioning a concrete panel w/ openings in elevation view |
Tue, Mar 25, 2008 at 3:07:22 PM
Smart Tags - Cast In Place Concrete Panels |
Thu, Sep 12, 2013 at 8:41:32 AM
Tilt Panel Concrete Walls |
Thu, Nov 30, 2017 at 9:53:05 PM
Getting my drop panel to show up with hidden lines correctly |
Thu, Mar 22, 2007 at 9:53:53 AM
Concrete panel 'tilt ups' |
Thu, Oct 30, 2014 at 8:11:10 AM
Members: | 2030725 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
