31 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Wall cut
![4 Stars: 10 Votes](/images/stars_4.gif) |
I have a wall that goes from the first floor up to the 2nd floor ceilng. Is there a way to cut that wall at the 2nd floor level as I need to change the upper wall to another wall thickness but I don't want to have to delete all the windows.
Appreciate any help.
Puzzle
Macca Sunshine Coast QLD Australia |
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
not sure i understand...
go to elevation and split the wall, 9dosent need to be accurate, you can adjust later) and change the top to what ever wall you want...
HTH
Thanks, somethings are just to simply.
Puzzle
Sunshine Coast
How Do I Cut Out Part Of The Wall? |
Wed, Apr 22, 2009 at 5:30:18 PM
5'8" wall will not be cut by cutplane |
Mon, Nov 13, 2017 at 3:49:59 PM
Diagonal End of Wall - Void + Cut Geometry not working |
Fri, Aug 30, 2013 at 3:25:08 AM
Void Cut Through Integrated Wall Sweep for Downspout |
Wed, Mar 2, 2011 at 7:59:51 AM
wall cut lines not displaying |
Fri, Sep 19, 2008 at 3:31:05 AM
Members: | 2025963 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
