66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Beam System Displaying Tags
Mon, Nov 14, 2011 at 11:50:47 AM | Beam System Displaying Tags
seniorcad143
1 Stars: 1 Votes
Why did this do this, and how do I make them look alike:Click image for larger version
Name:	plan joist.jpg
ID:	83077I would like to have the beam tag with the line and arrows not individually called out - how do I change this?
Yeesh - Where is My Cad
Mon, Nov 14, 2011 at 11:54:08 AM | Beam System Displaying Tags
seniorcad143
1 Stars: 1 Votes
Oh also - how do I get the two W8x10 lines to show as heavy a lineweight as the other beams?  And stop short of the other beams they are framing into?
Mon, Nov 14, 2011 at 12:24:58 PM | Beam System Displaying Tags
TKennedy
4 Stars: 7 Votes
IIRC, you need a beam system if you want a span tag instead of individual tags. Other things you can try is creating a new symbol, or use a dimension and override the text to say what you want.
For the graphics, check Object Styles and the Structural Usage for the beams.
Mon, Nov 14, 2011 at 12:29:26 PM | Beam System Displaying Tags
seniorcad143
1 Stars: 1 Votes
It is a beam system - see below.
Mon, Nov 14, 2011 at 12:48:01 PM | Beam System Displaying Tags
seniorcad143
1 Stars: 1 Votes
You know it seems to do it when I use skecth to put in the beam system - how do I change this?
Mon, Nov 14, 2011 at 4:21:57 PM | Beam System Displaying Tags
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
When you 'Sketch' the beam system it puts in individual tags. Delete them. Then click on one of the string tags that you like, click the 'create similar' button, click to select the 'sketched beam system' and click to place the good tag.
Tue, Nov 15, 2011 at 7:33:08 AM | Beam System Displaying Tags
seniorcad143
1 Stars: 1 Votes
Thanks - that did it!!!
Beam System Tags
Wed, Feb 27, 2013 at 12:55:27 AM
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
beam system displaying glitchy
Tue, Jan 12, 2010 at 7:33:44 PM
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:10 PM
Page generation time: 0.5193
