Forums >> Revit Building >> Technical Support >> Center of rotation symbol is missing
9 Posts No Rating |
We have a 4 building, multi-family project.
The files are linked into a MasterSite file.
The CENTER OF ROTATION symbol has gone missing but only in the MasterSite file. All other projects work fine. This happens on all workstations. Appears to be a project issue vs computer, installation, network type issue.
Anyone else experiencing this?
REVIT 2012 / update release 2
Missing? ... or you just don't see it? This sound like the center is way off in space because of the size of your view.
9 Posts No Rating |
Interesting thought. See attached screen capture. Looks like the center should be where the rotate line starts which is right in the middle of the object.
This happens on detail components as well as view tags like elevation symbols.
Might be a corrupted file since you say it in just that one file.
BTW - Do you ever clean up your errors? Not saying that is the problem but it is good practice. Mange tab - warnings.
9 Posts No Rating |
We are working on the warnings but there are a few.
We audit, purge, compact and archive regularly.
Corrupt file - any fix?
Weld symbol editing |
Thu, Jan 6, 2011 at 9:50:16 PM
Rotation |
Wed, Feb 27, 2008 at 2:28:49 PM
Elevation tag missing in Symbol Legend |
Tue, Nov 21, 2006 at 1:18:43 PM
Dynamic View Origin |
Thu, Oct 7, 2004 at 11:15:08 AM
Default 3D rotation view |
Thu, May 5, 2011 at 12:09:54 PM
Members: | 2115697 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
