Forums >> Revit Building >> Technical Support >> Problems with Complex Curved Curtain Wall. Help!
13 Posts No Rating |
Hi Everyone,
I have been trying to figure out how to fix the complex curved curtain wall I made. This is originally a mass I created, which I then loaded into my project, made walls, and when I try to make a curtain wall, it's really distorted. I am assuming because it curves really werid, it can't make it properly.
I tried dividing the surface in the original mass file, and then applying a pattern (rectangle) and then it just overlaps really weird :S It doesn't actually make a pattern.
Is there any way to make this actually work??
Thanks in advance.
I am also using Revit 2012.
Wish I could help with the modelling but that looks like a nightmare. Which leads me to ask - if it cant be modelled easily, how do you think they will ever be able to build it in reality?
----------------------------------- www.aspectarch.com |
I don't see how you can get linear & flat elements to work on a warped plane. Flat planes can approximate the surface but your vettical and horizontal elements can't twist.
You can create that with the "Conceptual Mass" and with a "Curtain Panel Pattern Based" family.
@ aspect - I am in design school, you imagine the impossible, even if it cannot be built
Thanks for your help! I simplified and essentially figured out the pattern based family.
Complex Curved Walls - please help |
Wed, Mar 25, 2009 at 5:26:10 PM
curved angled curtain walling |
Wed, Mar 8, 2006 at 4:18:50 AM
curved curtain wall, straight transoms, curved panels |
Tue, May 12, 2015 at 8:36:03 PM
curved curtain system -diagonal grid system? |
Wed, Feb 11, 2009 at 4:24:47 PM
curved curtain wall |
Sun, May 12, 2013 at 1:54:01 PM
Members: | 2115901 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
