73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Rotating the entire model to adjust for polar North
Sun, Nov 13, 2011 at 12:05:10 PM | Rotating the entire model to adjust for polar North
rkymtnrider
Hi. I'm the new guy.  As the subject line says, I'd like to rotate my model in an effort to align it with polar north. I have tried to select, and then rotate, but I received an error message that said I wasn't allowed to. I have searched as well, but I don't seem to come up with an exact "how-to". Could someone point me in the right direction? Thanks in advance.
Mon, Nov 14, 2011 at 3:46:28 AM | Rotating the entire model to adjust for polar North
4 Stars: 203 Votes
In your HELP menu search for "Rotating True North", also, look at the bottom of this page and you'll see similar threads.
Mon, Nov 14, 2011 at 9:08:31 AM | Rotating the entire model to adjust for polar North
rqtecht
@rkymtnrider
This can be difficult to understand for a new guy. I have to walk through it step by step myself each time but it is getting easier.
It sounds like you have the building already drawn. Do you also have the site already drawn? I believe I would take different approaches depending on the state of the project.
I always open up a site plan view which is set to TRUE NORTH and a plan view which is set to PROJECT NORTH. This way, I can see the changes as they take place. If your project is drawn to PROJECT NORTH, then that portion is taken care of. Go to your site plan view (set to TRUE NORTH) and then MANAGE > POSITION > ROTATE TRUE NORTH. It might help to make sure the SURVEY POINT and PROJECT BASE POINT are visible as well. They can provide a good reference.
I hope this is helpful. We typically draw the site plan first in TRUE NORTH so the process for us is rotating PROJECT NORTH. Once you get the TRUE NORTH set you can always change PROJECT NORTH for drafting purposes or to coordinate the two. Depends on how you work, I guess.
Let me know if I can help with more explaination or if I am of course. Typically, I am working with someone at the computer and it is easier to explain.
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:36 PM
Rotating views to project north
Mon, May 28, 2007 at 3:46:11 PM
Rotating Project North and Sheet view North not rotating
Mon, Oct 12, 2009 at 9:34:26 AM
Rotating Topo
Wed, Feb 3, 2010 at 6:45:54 PM
Rotating whole building to suit NORTH
Mon, Nov 26, 2012 at 5:06:53 PM
Page generation time: 2.4341
