54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dimensioning with linked DWG files
Sat, Nov 12, 2011 at 4:20:07 PM | Dimensioning with linked DWG files
awoolies
Hi,
When I dimension using an element in a linked DWG file as a reference and then if I have to reload the linked file, the dimension gets deleted and it becomes frustrating when there are so many dimensions like that - you can imagine. Is there a way to control this so that the dimensions do not get deleted when reloading the linked files? Appreciate any one's help!
aak
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:44 AM
Linked DWG Files not visable in RCP
Mon, Oct 19, 2009 at 1:46:59 PM
Overlays in Linked .dwg Files Showing Up in Revit 2013 Views
Wed, Sep 26, 2012 at 9:22:02 AM
Managing big linked files and exporting to 3ds max
Tue, May 11, 2010 at 8:06:16 PM
Detach from central - Linked files
Fri, Dec 16, 2011 at 12:50:04 PM
Page generation time: 0.6013
