51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Do we need a network license for our Revit in order to do Worksharing?
Fri, Nov 11, 2011 at 11:51:23 AM | Do we need a network license for our Revit in order to do Worksharing?
hgrimberg
I have 2 computers in my office with Standalone licenses for both revit programs installed on each of them. I create a Central file on one of the computers and then on that same computer, I create a local file and then another local file on the second computer. Then I click on save as/options and make that file, the central file, so that it is located on the 1st computer. On my 1st computer I can syncronize the local file with the central that is located on the same 1st computer but when I try to syncronize from the 2nd computer I get a message saying "File not save".
Is it because I don't have the network license for revit? (I am using revit 2010)
Fri, Nov 11, 2011 at 12:12:47 PM | Do we need a network license for our Revit in order to do Worksharing?
hgrimberg
When I check on the second computer what the syncronize settings are, I realize that the this 2nd computer routes the central file to the same location as if it is the 1st computer and does not allow me to set up a location in my office network. So if the central file location on the 1st computer is C:/XX_Central file.rvt, then on the 2nd computer the central file location is exactly the same and of course there is no such file on the 2nd computer's C drive.
Fri, Nov 11, 2011 at 12:20:15 PM | Do we need a network license for our Revit in order to do Worksharing?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
no you dont need a network license. You are pathing by C: and revit does not recognize drive letters. you need to path it differently.
if you are using one of the workstations as network host then i would create a shared partition. "location" \\RevitProjects or something of that nature
Edited on: Fri, Nov 11, 2011 at 12:22:37 PM
Fri, Nov 11, 2011 at 2:17:58 PM | Do we need a network license for our Revit in order to do Worksharing?
hgrimberg
Solved... it seems the file has to be on a 3rd computer...
Fri, Nov 11, 2011 at 2:22:46 PM | Do we need a network license for our Revit in order to do Worksharing?
alabaster2513
3.5 Stars: 25 Votes
glad you solved it, technically the central can be on a user workstation if you network it the way Revit requires.
LOST NETWORK LICENSE
Fri, Oct 15, 2010 at 2:36:37 PM
Network License Manager
Tue, Oct 9, 2007 at 8:27:07 PM
Some computers can't find a license
Mon, Aug 22, 2016 at 4:05:07 PM
Borrowing license to work at home
Mon, Aug 1, 2011 at 10:32:12 AM
Network issue with Revit MEP 2010 error 17
Wed, Sep 30, 2009 at 12:49:42 PM
Page generation time: 1.9202
