87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Tips & Tricks >> Rotate Tags
Thu, Nov 10, 2011 at 11:18:34 AM | Rotate Tags
SamLerman
Is it possible to rotate Annotation Tags 90 deg? As an example, I need to rotate Electrical Device Circuit tags.
Thank you
Thu, Nov 10, 2011 at 12:06:42 PM | Rotate Tags
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
it should just appear in the green toolbar
Thu, Nov 10, 2011 at 12:33:08 PM | Rotate Tags
SamLerman
Thanks to you I found the problem.
I've created this tag with "Rotate with.." checked. That why the box "Horizontal/Vertical" in the green toolbar was gray, and I could not select it.
Thank you!!
Rotate Door Tags -- Is this possible?
Thu, Aug 10, 2017 at 8:35:19 AM
Is it possible to rotate footing / elevation / etc. tags?
Tue, Feb 2, 2010 at 1:28:40 PM
Text in Section tags rotating
Fri, Mar 2, 2007 at 9:12:13 AM
ROTATE ELEMENT
Mon, May 16, 2011 at 8:15:08 AM
Rotating tags
Wed, Jun 11, 2008 at 2:21:50 AM
Page generation time: 4.8557
