62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> New family tamplate
![5 Stars: 12 Votes](/images/stars_5.gif) |
Here is a problem, when load family from metric library all very well and all the family there but when I go to new family command I can’t find any family template. Probably I didn’t define the path for them properly. Can someone advise me on that?
Regards
nirim
p.s. i have revit ARC 2011
Paths are set under the Revit R pulldown - options.
Hi there WWHub
Thanks for the comment.
The thing is that in my program data\ Autodesk\ RAC2011\ UK I have the family’s’ library files and not the families’ templates to use when creating new family. And nor are in the UKTempl. I set the file location to be:
Default template file = C:\ProgramData\Autodesk\RAC 2011\UKTempl\DefaultGBRENU.rte
Default path for user files = C:\ProgramData\Autodesk\RAC 2011\UKTempl
And Default path for family template file = C:\ProgramData\Autodesk\RAC 2011\UK
And still can’t find them.
nirim
Do a search on your system for *.rte files. Then set you path accordingly.
Templet |
Sat, Oct 27, 2012 at 6:52:33 PM
Create a family that includes another family |
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family? |
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project |
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message |
Wed, Aug 26, 2020 at 11:19:36 AM
Members: | 2022326 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
