68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Slabs
18 Posts No Rating |
Hello Revit Gurus,
I have two slabs. A structural slab and an architectural slopped topping slab. I need to model the void space between them so I can get quantities for what will end up being a "foam" filling.
Any Suggestions? i tried copying the slopped topping slab, moved it to the bottom face and tried to cut the excess with a generic void but the quantities did not change.
Thanks
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
Add the foam to your topping slab bottom.
Floor slabs showing dashed instead of Solid |
Wed, Jun 5, 2013 at 5:53:00 PM
12
Walls cutting slabs |
Fri, Jan 23, 2009 at 1:57:20 PM
highrise towers slabs-walls joining |
Tue, Jun 1, 2004 at 6:18:09 PM
new slabs, existing slabs, and the nature of constraint(s) |
Wed, Dec 11, 2013 at 12:21:24 PM
Sloped slabs and spot elevations |
Thu, Mar 6, 2008 at 1:18:13 PM
Members: | 2017271 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
