135 Users Online (134 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Creating ADA Sheet in Revit Template
Tue, Nov 8, 2011 at 1:58:12 PM | Creating ADA Sheet in Revit Template
DurangoArchiChick
Hello!
I am somewhat new to Revit and I am working on a template for our firm (a very small practice.)  I am wanting to make a new sheet with ADA diagrams from the new 2010 ADA Standards.  We don't have an existing library of these as CAD drawings so I was wondering the best way to go about finding these diagrams.  Is there a ADA database somewhere out there that would make it easy to import the diagrams as families?  I suppose I could save them as JPEGs and import them this way but this seems like a huge pain, plus the quality won't be great.  Any help on this topic is greatly appreciated!!
Tue, Nov 8, 2011 at 2:51:22 PM | Creating ADA Sheet in Revit Template
I suggest you don't use jpegs because they will really cause you problems.  I would create drafting views that you can port from project to project.   Import the diagrams once you find them and draw over them or simply draft them to scale.
Wed, Nov 9, 2011 at 11:15:06 AM | Creating ADA Sheet in Revit Template
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Most of the necessary drafting tools are in Annotation Tab. This is an acceptable way, but I show everything each time, we are making models, and that is the whole point. If you use the ADA, sinks, and toilets, and all the other parafanalia, you will get the real thing. Which is what is really needed for the contractor.
Wed, Nov 9, 2011 at 11:33:10 AM | Creating ADA Sheet in Revit Template
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
nice to see a durango person on here. I use to be in architecture in durango too.
Ada Componets
Thu, May 7, 2009 at 10:49:03 AM
Correct family template for a sheet "stamp"?
Mon, Jun 27, 2011 at 5:10:23 PM
Creating a template
Tue, Jan 31, 2006 at 12:38:53 PM
creating sheet frame using dwg file
Tue, Nov 1, 2005 at 11:35:09 AM
ADA symbols???
Wed, Aug 5, 2015 at 9:17:21 AM
Page generation time: 4.1761
