86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Reversing Grid naming of columns?
Mon, Nov 7, 2011 at 8:17:08 AM | Reversing Grid naming of columns?
robsloyer
Revit identifies columns by the gridline coordinates at which they appear.  So columns “A-1” for example.  It appears to use a convention of listing the vertical gridline first, then the horizontal (looking at plan view).  Is there a way to reverse this?  The structural engineer on the project I’m working on appears to prefer the opposite, and it makes checking my schedule against his rather tedious.
Mon, Nov 7, 2011 at 9:32:57 AM | Reversing Grid naming of columns?
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
There is no workaround... just renaming all the grids manually. In order to not make mistakes, when i rename grids, i check a list made in excel with the corresponding letters, that prevents mistakes when the list is too long.
Linking columns to grid lines
Fri, Sep 26, 2008 at 11:12:58 AM
need to lean columns to match shifting grid
Mon, Sep 24, 2007 at 1:20:52 PM
columns grid elbow copy
Fri, Aug 2, 2013 at 7:55:14 AM
columns in walls
Mon, Sep 11, 2006 at 11:53:37 AM
Grid Lines at Face of Steel, Not Centerline
Thu, Mar 19, 2015 at 3:16:30 PM
Page generation time: 0.3510
