84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> text on rendering view
Tue, Dec 6, 2005 at 11:07:02 AM | text on rendering view
orv
4.5 Stars: 7 Votes
Does anybody can help me to use text on rendering view...im tring to do a wallpaper with my jpg (revit view) and more other information like phone number, email , local, description of house..etc! i need to do this on a very large size to put on the construction place.tanks
Tue, Dec 6, 2005 at 3:56:07 PM | RE: text on rendering view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Revit has very limited image manipulation tools. Best to use photoshop or similar if you want to start blending images. You just place the text like any other text? Not sure what issue you are having?
Tue, Dec 6, 2005 at 5:12:40 PM | RE: text on rendering view
geoffy
Do you mean you are trying to place a JPEG image onto a modelled water tank? You can use the DECAL tool to do this. In a nutshell- 1/ pick the decal tool from the Modeling tab in the Design bar 2/ select the JPEG image you wnat (it must be at "full size" to avoid pixellation if you increase the size from a normal photo size) 3/ you can adjust settings for reflection of the image etc. 4/ run the render and you will see you JPEG image on the tank. I have given you an example on a circular brick wall I hope this helps/what you wanted answered!
Tue, Dec 6, 2005 at 7:19:38 PM | RE: text on rendering view
Roger Evans
You can try exporting your 3D view as jpeg Then open a new blank view & import jpeg Add Text Or If you make Workplane then text can be written (but will also read backward when you spin) so decide on your orientation first
Thu, Jan 26, 2006 at 10:56:03 AM | RE: text on rendering view
orv
4.5 Stars: 7 Votes
what do you mean when you say a new blank view?Can it be any view like 3D view or an elevation? I have been trying in a elevation view and it works!but dont know if its the best way to do it! thanks Ruben
Rendering Text
Wed, Dec 10, 2008 at 4:47:02 PM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:16 PM
Text and gridlines in a Revit 3D view
Wed, Mar 25, 2009 at 6:53:54 AM
View References in Text and Keynotes
Fri, May 22, 2015 at 1:05:21 PM
View Rotation - Dimension text
Thu, Jul 21, 2016 at 12:06:49 AM
Page generation time: 2.9325
