Forums >> General Discussion >> Revit Project Management >> Pattern (.PAT) Files
Using Revitcity, how could I obtain a .pat file, if possible. Tried searching and specifying I want a .pat file, but got to no hits. Otherwise, where in the MasterFomat 04 could I find any available pattern files.
Alternatively, any hits or links to places where I could get fill pattern files for revit would be muchly appreciate. I also know that it is possible to get an AutoCAD pattern and use it in Revit, but am not really sure how to do that. If someone knows more about that, please feel free to shed some light onto it.
How about here?
Very neat indeed! Thanks! Sadly, I couldn't find a ridig insulation pattern in there either probably because it is impossible to be made as a pattern. I know that I can always do it as a detail component as a zig zag line, but would really like to have it as pattern as well since sometimes my insulation, at roofs for example, would be wedge cut. Any ideas how to work around that?
Ah... try to make a detail line based, with an array (instanced) thats overrided by the default lenght. In those cases when the insulation makes tricky things, just do detail lines.
The Pattern works well if you insert it as a "Drafting pattern".
The easiest way to use it is to use an existing pattern and "EDIT" it.
Double click on the pattern you want to edit, then a browser opens up. Find the file that you downloaded (zip file is best)
to insert it, you have to use the " DRAFTING" preset.
Then it will work. You can adjust the scale to fit.
Use Pat Files |
Tue, Sep 1, 2009 at 4:18:41 AM
11
Pat files corrupt |
Thu, Jan 22, 2009 at 3:20:13 PM
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder? |
Mon, Jul 6, 2015 at 11:01:27 AM
Import PAT File |
Tue, Dec 14, 2010 at 9:42:44 AM
Pattern files |
Sat, Sep 16, 2006 at 5:11:35 PM
Members: | 2098045 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
