51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Tips & Tricks >> Tension Structure/Membrane
Sun, Nov 6, 2011 at 2:20:29 AM | Tension Structure/Membrane
Archit144
I have been trying to create a tension system in Revit Architecture, but I have has no luck. I have tried useing the loft and blend tools but i just can ge the shape or the editing capabilitys that I need for this project. Im sure that there is something I'm missing but i just can't see it. Is there anyone that knows how I might make something like this.
Sun, Nov 6, 2011 at 7:50:07 AM | Tension Structure/Membrane
4 Stars: 202 Votes
"Conceptual Mass" is the way.
Import that CAD file then create points and adjust them, create reference lines (Lines, Splines...) now select those ref. lines and "Create Form", you can adjust those point after you created that surface.
Hope This Help
tension membrane structures in Revit
Sat, Feb 4, 2012 at 6:19:59 AM
Tensile Membrane Structures [ 1 2 ]
Fri, Oct 1, 2004 at 10:43:14 AM
21
Tension Cable
Sun, May 27, 2012 at 6:54:39 AM
What's the Point of the Membrane Layer
Mon, Nov 11, 2013 at 5:11:55 PM
Errors using Membrane Layer: zero / non-zero thickness
Wed, Aug 7, 2013 at 6:08:50 PM
Page generation time: 0.4930
