69 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> toposurface
4 Posts No Rating |
I am having trouple with creating subregions on a toposurface.
I created the toposurface from an imported cad format.
On a certain section of the surface it does finish the subregions but on the other side it says " The Site Surface failed to triangulate."
Please help if possible.
Urgent.
Thanks
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
make sure that all your lines have a correct Z value and not all over the place, also, make sure they are closed...
sometime when data is missing it fails...
4 Posts No Rating |
double checked all and thy still dont work.
Can,t even coppy existing subregions to this negative area.
Gives the same error report.
Any other solutions?
Thanks
![3 Stars: 1 Votes](/images/stars_3.gif) |
I've found that Revit is very good at generating topography from AutoCAD files, but very poor when you want to edit the surface in any way (especially for large sites). I got the same error frequently ( The Site Surface failed to triangulate.) If you have to show roads and pathways (subregions) in any 3D view I can't give you much help, sorry. But if all you want to do is show the roads and pathways in plan view on a large site model, I've resorted to importing DWGs and overlaying the information. Hope that helps.
Use the simplify surface tool before applying the subregions.
This will remove excessive points and hopefully fix this problem. The resulting simplified surface is nearly exactly the same as the original in most cases just simpler...
Flat Toposurface |
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations |
Thu, Aug 27, 2009 at 1:51:06 AM
what is the easy to do toposurface |
Mon, Feb 27, 2006 at 8:44:07 AM
14
Toposurface |
Tue, May 11, 2010 at 9:04:45 AM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
