45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Spot Elevations
Thu, Nov 3, 2011 at 3:09:16 PM | Spot Elevations
bajoyce
bajoyce Avatar
3.5 Stars: 3 Votes
other than using "text" annotation, does anyone know a better way to use the Spot Elevation to show the top of deck to not include the finish material/layer?
Thu, Nov 3, 2011 at 4:15:59 PM | Spot Elevations
cobblea
Is this for a floor object that you are showing in plan view?  If you modeled the finish floor as a separate sketch (and a separate floor type), you could set up a parameter called FINISH FLOOR (or something like that), and then set up a filter to hide the offending objects.  You would then be left with a floor plan that shows your concrete deck/ etc, which you could then spot-elevate to a nice clean number.  Does that help?
By the way, this technique is also useful to hide carpet, tile, and other finishes in floor plans,while still letting you shown them in finish floor plans.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:28 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:54 PM
13
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:14 PM
Page generation time: 0.3963
