59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Make Walls Grey and Transparent in Plan view 'Fine Detail'
Wed, Nov 2, 2011 at 2:25:47 PM | Make Walls Grey and Transparent in Plan view 'Fine Detail'
maddyjdel
Is there a way to make my walls in plan view appear as such (see attachment) in "fine detail view (as opposed to Coarse detail view)"!? I changed the coarse fill Pattern to Solid and coarse scale fill color to Grey in the Graphics box, but when I switch to Fine view, it reverts back to white!? I hope this is making sense!? Thank you so much in advance! You revit experts are the best!!!!
99081_Wall_Fill_Grey.tif
Wed, Nov 2, 2011 at 9:14:13 PM | Make Walls Grey and Transparent in Plan view 'Fine Detail'
revitSHS
Do you mean that it is changing from Gray, when 'coarse', to White when 'fine'? If so, I believe that it should stay the same unless your details are set to hidden line or wireframe.
Thu, Nov 3, 2011 at 7:30:57 AM | Make Walls Grey and Transparent in Plan view 'Fine Detail'
In fine / medium mode, cut patterns are assigned by material - not by wall definition.
How did you create that image?  You say it is a coarse view that you changed your fill?  I doubt that.  Coarse views will not show layers and in addition to that, you can't create a fill that has both a solid fill and a pattern.
Are you teasing us with something we are not aware of? - Fess up.
Problem with 'Coarse' & 'Fine' view options
Thu, May 16, 2013 at 2:07:41 AM
fine detail missing on duplicated wall, plan view??
Mon, May 1, 2006 at 8:31:21 PM
When I make an ''Area plan'' not all the original elements show up.
Thu, Aug 15, 2019 at 8:17:47 AM
Wall in Plan View: Details
Tue, Mar 12, 2013 at 11:23:00 AM
Grey out Truss
Thu, Jan 5, 2006 at 10:04:53 PM
Page generation time: 8.0131
