97 Users Online (96 Members):
Forums >> Revit Building >> Technical Support >> topography
5 Posts No Rating |
I am having problems with my sections, I cannot get the topography out of the building and it is not allowing me to put furniture on the floor. I am also having problems creating walkways and coloring the grass green. Also, how to make a parking lot of a sloped surface.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
WELCOME
to cut topo out of your section, you will need to put a pad under the building, refer tutorial.
to create walkways, you will need to use floors and ramps and if it's a complicated site, you can refer to my tutorial on creating complex slabs and walkways...
to get the grass bit, you will need to split surface.
TOPOGRAPHY SPLIT PROBLEM |
Mon, Sep 22, 2008 at 2:51:42 PM
Topography |
Wed, Oct 19, 2016 at 6:19:21 AM
Topography dissapearing |
Wed, Nov 7, 2012 at 2:46:15 PM
Creating levels below topography/raising topography? |
Fri, Apr 12, 2013 at 1:22:50 PM
Extend topography. |
Mon, Mar 26, 2007 at 8:21:29 PM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
