Forums >> Revit Building >> Technical Support >> Ref Planes
Mon, Dec 5, 2005 at 7:11:44 PM | Ref Planes
bobbo
I've got two types of trusses along side each other I have drawn a ref line down the slope of the larger trusses and saved it. The smaller series of trusses across a verandah are causing me problems. I have tried to get them aligned to the larger trusses vai the ref line but to no avail. I select one of the smaller trusses and TOOL>Set Work Plane but no luck. I have just drawn individual trusses rather than a beam system under Structural. Can anyone help
Mon, Dec 5, 2005 at 10:48:05 PM | RE: Ref Planes
eldados
eldados Avatar
4.5 Stars: 8 Votes
try deleting your little truss, set the work plane to your reference plane and draw it again...
Integrator
KarelCAD
Wish List - Toggle Reference Planes
Fri, Sep 24, 2010 at 1:23:59 PM
how to change defined ref planes in a family
Mon, Apr 18, 2011 at 2:07:00 AM
How Can I Change The Dimensions Of A Window To A Specific Custom Size?
Tue, May 26, 2009 at 7:28:02 AM
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Nested Family won't lock to 2 ref planes/lines
Fri, Jan 17, 2014 at 10:09:19 AM
Page generation time: 1.1602
