119 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Bracing not joining beams ;(
Thu, Oct 27, 2011 at 10:49:36 AM | Bracing not joining beams ;(
JRPcad
Not sure whether I should be posting this in structure or not, but I am using architecture to make it:
See attached part of a bit of framework that I'm trying to build from the attached picture. I could build with in place modelling but I want to do this properly using beams, columns and bracing, i've managed to get the beams to join as you can see using beam column joins, but cant seem to manage to get the bracing to join in the same way.
Can anyone shed some light on what's going wrong, I do need one to be oval and one circular if maybe that's causing the problem.
Thanks
Edited on: Thu, Oct 27, 2011 at 10:50:33 AM
For Architectural Services visit www.jrpcad.co.uk
Thu, Oct 27, 2011 at 10:51:16 AM | Bracing not joining beams ;(
JRPcad
heres a pic of what i'm trying to model
dunno why my pic won't attach as it's only 400kb, still should be able to get info needed from the rvt file
Edited on: Thu, Oct 27, 2011 at 10:54:22 AM
Thu, Oct 27, 2011 at 11:21:44 AM | Bracing not joining beams ;(
JRPcad
Okay I just tried this in @Revit structure and still the same issue, even tried with just standard CHS, and still the same issue. Does this mean that it's a standard thing that the bracing doesn't join the rest of the model??? seems very strange and looks very odd when coming to present work or colaborate with the architects 3D model.
I've got a large roof structure to model with lots of fancy truss systems, does this mean that the only way to make it look decent is to inplace model all of the bracings???
Please help someone.
Help joining and trimming beams
Thu, Jun 23, 2005 at 4:37:51 PM
BEAMS JOINING COLUMNS problem
Tue, Jun 30, 2015 at 7:41:52 AM
Kicker Bracing
Tue, Apr 30, 2019 at 12:03:08 PM
Joining Beams
Tue, Feb 19, 2013 at 9:50:07 AM
Coping Tool not joining columns to bracing of SHS type families
Fri, Jan 13, 2012 at 11:34:35 AM
Page generation time: 0.8653
