69 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> Revit 2011 Multiple Interior Elevation References
1 Posts No Rating |
How do you place multiple references to the same interior elevation? There are multiple classrooms in the building I am working on that have the same interior elevation. Is there a way to have multiple elevation tags on a plan referring to the same interior elevation? (I have a similar issue with callouts - typical plans to be referenced on different floors, should this be a different thread?)
This process in Revit is "Reference other view" and you can do this with any view type. Just start the elevation/section/detail process but before placing it on the view, select "reference other view" button on the options bar and then select the view to be used in the view drop down.
Searching your HELP with the term "reference" and you will find several guides on this process.
Interior Elevation References |
Thu, Jun 28, 2007 at 8:27:06 AM
2011 interior elevation tags |
Thu, Dec 23, 2010 at 11:44:57 AM
Interior Elevation Tags |
Wed, Oct 9, 2013 at 2:23:36 PM
Elevation Bubbles - Duplicate Views |
Tue, Nov 13, 2007 at 8:55:24 AM
REVIT 2011 Crashes Dealing w/ Interior Elevations |
Tue, Jul 31, 2012 at 1:57:42 PM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
