36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Tips & Tricks >> stair plan
Wed, Oct 26, 2011 at 3:06:23 AM | stair plan
albertiglesia
albertiglesia Avatar
hi,
why everytime i create stair (monolitic) and see it from level to, the steps beyong cut line is still continious line NOT dash or hidden line?! also the break symbol is not showing on the upper level plan of the stair, it only shown in the lower level of stair plan
"Pleasure in the job puts perfection in the work"
 - Aristotle
Wed, Oct 26, 2011 at 12:31:02 PM | stair plan
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
check two things, draw a section through your stairs, verify that they are indeed going the direction that you thought they were. then make sure that you are on the correct floor, and that your veiw range is set properly.
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN
Fri, Sep 2, 2016 at 7:03:04 AM
stair not showing up as it should be in plan region
Fri, Oct 30, 2009 at 11:46:35 AM
Plan Regions Cutting Stairs
Thu, May 26, 2011 at 6:14:13 PM
CanĀ“t see entire stair
Fri, Sep 13, 2013 at 2:16:01 AM
Stair Plan Enlargements
Mon, May 7, 2007 at 6:33:42 AM
Page generation time: 2.2664
