Forums >> Revit Building >> Technical Support >> Glass Panel Baluster Issue
I've been working to create a star with a glass railing where I'm using a baluster template. Among other issues, I've been having a strange thing happen as I've been making adjustments and wanted to see if anyone had encountered it and found a solution. The baluster/Glass panel I'm using is supposed to have 1" gap top and bottom per template file.
Just kidding. This site is not allowing me to attach images for some reason. What is happening is that the bottom of the glass panel baluster is changing arbitrarily as I make adjustments. Some of them are appearing correctly and others are different. There's no other offsets applied to baluster placement. Does that make sense?
Image must be small enough to attach. Use a small gif ...I use Screenhunter free to screen capture small image files. Also, you can use IE of firefox / mozilla 5.0 or earlier. Chrome and later firefox do not work here.
In your baluster family, are the base constraints for the modeling locked to a reference plane? If uploading files fails, you can use an image hosting site like Imgur or Photobucket in a pinch.
I'm trying the gif through IE. And yes the extrusion is locked to the reference plane in the family.
Dont know why I cant post an image. Its just a screen capture under 200kb. Strike three.
Too many locks. You want to lock the sketch lines of the railing panel to the reference planes, not the other way around.
edit: attached... no... attachments are acting funny today on revitcity.
Edited on: Tue, Oct 25, 2011 at 4:43:03 PM
Attempt two to upload family.
Thanks for looking into that! I will give it a try tomorrow and see how it goes. I appreciate it!
U might try Jing, for image capture.
So I'm still having the same problem as well as another new one that I believe I've seen in other posts. The bottom of the baluster is offsetting from the base incorrectly and the panels are extending past where they should stop. I suppose the latter is solved by creating a seperate panel family that is exactly the dimension of the odd bits. Not sure what else to do other than simply abandoning revit railings and create them using curtain walls and sweeps.
and still no attached images! Ugh! Revit City, fix this please!
Glass Baluster Pattern extends beyond segment end |
Thu, Mar 14, 2013 at 9:59:59 AM
Stair Baluster Panel Pattern Length |
Mon, Oct 15, 2007 at 10:04:52 AM
stair railings-inserting glass |
Mon, Dec 9, 2013 at 11:37:40 AM
railing with glass or solid |
Wed, Apr 30, 2008 at 5:28:23 PM
creating baluster panel with 45 degree bars (2023) |
Mon, Jul 10, 2023 at 4:35:09 PM
