Forums >> Revit Structure >> Technical Support >> continuous sweep memebrs
140 Posts No Rating |
I was wondering if anyone new of a way to make a continuous sweep element such as edge angle that is not a model in place family or individual "elements" at corners. I would like to be able to draw lines for the member (generic model?) on multiple faces and have them join to appear mitered?
Any ideas. . . it works great when it is an inplace family, but i cannot figure out how to have multiple segments in a family (variying in quantity).
Thanks, GReg
Your question is not very clear. You want a sweep but not a model in-place. You say model-in-place works but not for multiple segments. Both of these are contradicting. A description or images of your desired end results would help.
WWHUB,
Thanks for the reply, i agree that I did not articulate very well. I attached a .dwfx file of a model-in-place component. I would like to have a family that would allow me to input this in a similar way. For the model in place, I chose sweep and sketched my path, then chose my profile. When I sketch my path I can choose a line with as many segments as i would like.
I would like to use a family in lieu of model in place. Is there a family or an option that will put me in a sketch mode?
I think modeled in place is the way to do this. There's nothing wrong with modeling in place, and I can't imagine a way of making this work without something like adaptive components, which would be much more trouble than its worth.
What are you trying to model?
i was hoping to have nice clean miscellaneous steel in the model for our architects. Everytime you make model in place components , they require a uniqu name. I gues I was hoping to have an option of "laying out" via a sketch or something. Thanks for your thoughts.
Non-Continuous, Repeating Wall Sweep |
Wed, Jun 29, 2011 at 10:49:55 AM
Interrupted Guardrail with Continuous Handrail - Revit 2013 |
Thu, Feb 20, 2014 at 12:16:31 PM
trimming vertical mullions to continuous border mullion |
Tue, Aug 13, 2013 at 5:28:05 PM
non-continuous handrails |
Mon, May 20, 2013 at 3:10:42 AM
Wall sweeps ignore room boundaries |
Wed, Nov 3, 2010 at 10:30:51 AM
Members: | 2115615 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
