83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2011, Creating a wall with an angled end.
Fri, Oct 21, 2011 at 2:33:17 PM | Revit 2011, Creating a wall with an angled end.
hcjames570
Is there a simple way of creating a wall that has an angled end profile?
Fri, Oct 21, 2011 at 2:46:42 PM | Revit 2011, Creating a wall with an angled end.
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
sadly, no.  Cutting it with an in-place void family is your best bet.  I wouldn't be surprised if someone has uploaded a wall-based parametric family that can cut its host at a user-specified angle.   That would also be pretty easy to make.
Fri, Oct 21, 2011 at 3:12:58 PM | Revit 2011, Creating a wall with an angled end.
itsmyalterego
4 Stars: 16 Votes
decided I shouldn't  make promises like that...
Here's a family -- revit 2012, which allows you to place on a wall surface a void family which will cut the wall at an angle you specify, to the height you specify.
sort of a crude, quick family, but it saves time over modeling a ton of individual voids.
Mon, Oct 24, 2011 at 8:11:19 AM | Revit 2011, Creating a wall with an angled end.
hcjames570
That is what i thought...thank you very much for the tip and the example.
Mon, Apr 14, 2014 at 4:09:17 PM | Revit 2011, Creating a wall with an angled end.
roddmc
I know this is an old thread, but we came up with an innovative solution. Create a new wall that is in the position of the cut you want. Put it in a future phase (that will never be shown). Voila. The new wall cuts a hole in the existing one.
Tue, Apr 15, 2014 at 7:00:18 AM | Revit 2011, Creating a wall with an angled end.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Using a future phase doesn't sound like a very good idea to me.  May want to just create a family instead.
Mon, Sep 22, 2014 at 8:26:45 AM | Revit 2011, Creating a wall with an angled end.
Araanim
If you can, try adding a tiny bit of wall that turns the corner, then put a sweep or reveal on the face of that wall so it essentially forms the end of the main wall.  It's finicky and hard to do perfectly, but it's the best I've come up with.
Mon, Jun 8, 2015 at 11:21:02 AM | Revit 2011, Creating a wall with an angled end.
DavidLarson
You guys are awesome.  Thanks for providing the family.
Do you even Revit bro?
Wed, Feb 7, 2018 at 10:55:54 AM | Revit 2011, Creating a wall with an angled end.
4kopstudio
There is no easy way, but I made a video about it.
https://www.youtube.com/watch?v=VfOpF3EYmjg
REVIT 2013 - Angled Layered Wall Ends
Tue, Dec 3, 2013 at 8:18:34 AM
Revit 2011-putting openings in angled walls.
Sat, Sep 10, 2011 at 5:45:28 AM
Angled Wall Sweep End
Thu, May 7, 2009 at 10:56:29 AM
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:54 PM
angled roof / wall
Wed, Feb 20, 2008 at 9:30:55 AM
Page generation time: 2.7063
