89 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Shear wall tag with label that reads wall length
Thu, Oct 20, 2011 at 11:45:01 PM | Shear wall tag with label that reads wall length
bizz3d
I would like to make my shear wall tag read the shear wall family's length. I don’t want my users to manually input this information and possibly make a mistake.
How do I make the label pull the length information from my shear wall family?
Fri, Oct 21, 2011 at 7:12:30 AM | Shear wall tag with label that reads wall length
I don't believe there is any way to tag the length of a wall but it can be scheduled.
Fri, Oct 21, 2011 at 10:44:39 AM | Shear wall tag with label that reads wall length
bizz3d
What about building a generic family with the label? Could the label read the length then?
Fri, Oct 21, 2011 at 10:57:46 AM | Shear wall tag with label that reads wall length
TKennedy
4 Stars: 7 Votes
I think I'd do it with two families, one detail component and one nested symbol. I've attached a family as an example, it's extremely basic but should get the point across. It's not actually a tag so it won't automatically read the wall length, but it can be locked to a wall and it will read and display the length.
Fri, Oct 21, 2011 at 1:37:31 PM | Shear wall tag with label that reads wall length
bizz3d
Thank you TKennedy but I do not see the attached sample you mentioned. Can you please repost and once again thank you for the sample.
Fri, Oct 21, 2011 at 4:26:50 PM | Shear wall tag with label that reads wall length
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
This is a shear wall symbol that I fooled around with. I was hoping to be able to set tags to each end, but haven't got that far yet. Anything you can do to improve it would be great.
Fri, Oct 21, 2011 at 5:57:36 PM | Shear wall tag with label that reads wall length
TKennedy
4 Stars: 7 Votes
Doh. Forgot to attach it.
Shear Wall Length
Tue, May 24, 2011 at 5:00:46 PM
Shear Wall Symbol
Thu, Oct 22, 2009 at 10:29:42 AM
wall tags - shear wall tag on exterior (sheathed) side of wall?
Tue, May 26, 2009 at 9:55:17 AM
Partially Underline Text in a Label?
Tue, Jul 24, 2012 at 3:11:12 PM
Shear Wall Calculations using Revit !!
Fri, Nov 21, 2008 at 4:03:37 AM
Page generation time: 1.1864
