98 Users Online (97 Members):
Forums >> Community >> Newbies >> Door and window tags
2 Posts No Rating |
I need to change door and window tags and use the new tags to create a schedule. I have the schedule set up but need a little help changing tag symbols and numbers.
Download the "families guide" from the autodesk site. It will help you with modifying a tag.
The tag's value is a property of the component being tagged. It might be an instance or a type parameter. Click on the object and change its value. You can also change it in the schedule if it is instance based.
1 Posts No Rating |
I was looking for the same thing thank you
Blackout Vertical Blinds |
Room Window and Door Tags |
Thu, Nov 15, 2007 at 9:21:10 PM
Deleted dimensions, door tags and window tags |
Wed, Jul 18, 2007 at 10:57:29 AM
window/door tags |
Mon, Oct 23, 2006 at 6:35:45 PM
Putting Window and Door Tags in Door and Window Schedules |
Thu, Mar 12, 2009 at 1:38:06 PM
window and door tags |
Mon, Mar 8, 2010 at 10:42:57 AM
Members: | 2022270 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
