91 Users Online (90 Members):
Forums >> General Discussion >> Revit Project Management >> Compact Central File before Upgrade
![tmassey Avatar](user_avatar/248784.jpg)
167 Posts No Rating |
I was told by our IT department that in order to ugrade from any version in revit from old to new, you must compact the central file first in the original version before the upgrade. Compacting acts as a defragmenter. Sounds odd but if it must be done.
Is this true?
Using Revit Architecture 2012 |
26 Posts No Rating |
I've never heard of anything like this. Does "compact" mean compressing the file into a zip-folder? because that wouldn't make any sense. Maybe they mean "purge" rather than "compact". That might have some merit.
There is so much information in Revit's HELP if people would only look. Searched "upgrade Revit" and you will find:
"Upgrading Workshared Projects" This tells you what you should do and there is nothing about compacting the file in the old version.....
![coreed Avatar](user_avatar/14568.jpg)
i think that i would advise before upgrading is to correct as many of the outstanding "warnings" as possible.
Edited on: Wed, Oct 19, 2011 at 10:25:26 AM
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
I realize this thread is a little dated but the recommendation is the run an Audit while opening and upgrading the central file in the new version of REVIT. Audit and Compact are two seperate operpations.
Compact File? |
Mon, Aug 18, 2008 at 8:46:31 AM
compact central |
Mon, Aug 15, 2011 at 5:45:36 PM
Compact file during Save As |
Wed, Feb 16, 2011 at 9:29:18 AM
detach from central file |
Wed, May 12, 2010 at 12:28:23 PM
can't save as a central file |
Wed, Sep 9, 2009 at 2:35:47 PM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
