97 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> invisible ceiling pattern
Mon, Oct 17, 2011 at 6:50:24 AM | invisible ceiling pattern
brionymaex
Hi I just applied a ceiling pattern to my ceiling however it doesn't seem to be visible. I selected element properties, edit type then changed the coarse fill pattern from solid to hatch but yet I can't see anything.. what am I doing wrong?
Mon, Oct 17, 2011 at 7:20:12 AM | invisible ceiling pattern
The pattern has to be assigned to the materials, it is NOT a coarse/fine value.   VG has to be set to show the ceiling and no pattern over-rides on the ceiling.  You also need to be in a RCP or a 3D view where you can see the ceiling.
This user is online
ceiling hatch pattern
Thu, Apr 17, 2014 at 6:59:11 AM
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:43 AM
14
How to make ceiling grid with a pattern on it
Mon, Aug 11, 2008 at 2:21:08 PM
I need a simple hatch pattern for a waffle ceiling
Fri, Jan 18, 2008 at 12:53:45 AM
Sloped Ceiling Surface Pattern Not Visibile
Sun, Jun 26, 2016 at 7:21:37 PM
Page generation time: 0.3859
