38 Users Online (37 Members):
Forums >> Revit Building >> Technical Support >> Material area of part in door family isn't correct
2 Posts No Rating |
I have used the door family (attached to this thread) in my project.The folowing parts with material parameter are drawn in this family:- The door (BE Deurblad Materiaal)- the frame (BE Vast Kader Materiaal)- the beam that supports the bricks above the door (BE Linteel Materiaal)- the profile under the door that is used to seperate the floorfinishing. (BE Tussendorpel Materiaal)I gave only the beam a materialWhen I extracted the area and the volume when it was placed in a wall, they were both not correct.When I gave the profile a material (different from the beam) then the volume of the beam was correct but the area still wasn't.I've searched what number the diplayed area is equal to. And I found it. The area that is displayed in the skedule is the sum of the areas of the 6 faces of the beam.Does anyone can explane this? What can I change to the family to get the correct area?Thanks
2 Posts No Rating |
I use Revit Architecture 2012 update 1
"Family is not of the Correct Catagory" |
Thu, Feb 17, 2005 at 11:59:43 PM
Door color varies in different views [ 1 2 ] |
Wed, Nov 14, 2012 at 2:39:14 PM
17
Can I make ''Area'' colors opaque to dwg that exists underneath the area plan? |
Fri, Nov 22, 2019 at 12:27:55 PM
Hatch rotation in door family |
Wed, Jan 21, 2015 at 11:55:18 AM
revit material part take off result does not equal original walls |
Wed, May 29, 2013 at 7:58:30 PM
Members: | 2017233 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
