53 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof Footprint - Fillet corners
Fri, Oct 14, 2011 at 10:53:12 AM | Roof Footprint - Fillet corners
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I'm trying to create a flat roof with round corners but I keep getting "can't make footprint" when creating the boundary. Is there something I'm missing? To get around it, I made a floor with the same structure and it works and then I'll create the fascia with an in-place sweep but there must be a way to use the roof properly, right?
Fri, Oct 14, 2011 at 11:14:46 AM | Roof Footprint - Fillet corners
I have no problems doing this in 11 and 12.  Did you turn off the defines slopes for those corners?
Fri, Oct 14, 2011 at 12:17:58 PM | Roof Footprint - Fillet corners
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
your the man WWHub! I thought giving it a zero slope would do the job but turning off 'defines slope' worked. Thanks.
Stacked wall problem - corners do not fillet.
Wed, Jul 16, 2008 at 11:40:40 AM
ROOF Corners - TWO different Slopes
Tue, Jul 18, 2006 at 10:26:15 AM
Fillet arc not working on baluster panel extrusion
Wed, Oct 26, 2011 at 5:56:35 AM
How to drop one side of a revit roof from footprint ?
Thu, Jan 6, 2011 at 4:37:42 AM
3D Fillet/Chamfer
Thu, Sep 2, 2010 at 5:31:43 PM
Page generation time: 0.4259
