140 Users Online (139 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> HELP! I just rendered an Image and it wont export or save!
Fri, Oct 14, 2011 at 5:16:31 AM | HELP! I just rendered an Image and it wont export or save!
jpfendler
I just rendered an image that took 4 hours to complete and noe it wont save to the project or export! I really need it this morning so what do I do? Thanks.
Fri, Oct 14, 2011 at 8:10:32 AM | HELP! I just rendered an Image and it wont export or save!
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I've had this happen before too. I left a render going overnight and in the morning, it was finished and looked great but I couldn't save it, all the button were frozen. My only option was to hit 'print screen' and then paste and crop it in Paint, how embarrasing. I lost the quality that I wanted but was atleast able to provide something at the deadline.
Fri, Oct 14, 2011 at 9:54:26 AM | HELP! I just rendered an Image and it wont export or save!
jpfendler
  I guess it was just too big of a file (30 MB). When I do test renderings with screen resolutions I can save just fine. It's kind of crazy there is no warning or dialog box though. I am also rendering on a laptop but still it's crazy.
Fri, Oct 14, 2011 at 9:59:04 AM | HELP! I just rendered an Image and it wont export or save!
If I remember correctly, if you try to save to file first and there is not enough memory available, your up the creek.  You should always pick export first, then try to save to project if you really want it in the project.  Most times I don't.  If I need it later, I can always insert the image that I saved.
Rendering problems
Tue, Sep 18, 2012 at 8:48:18 AM
Export an Image shortcut help.
Wed, Feb 10, 2021 at 10:33:57 AM
Capture Rendering/Export Image
Wed, Aug 15, 2007 at 10:34:26 AM
Exporting & Saving Renders
Tue, Aug 13, 2013 at 7:46:25 PM
Help - My render won't export
Thu, Dec 18, 2008 at 10:54:52 AM
Page generation time: 0.8288
