50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> occupant load factor
Thu, Oct 13, 2011 at 8:20:46 PM | occupant load factor
brandino
How do you create a field/parameter to a schedule that applies an Occupant Load Factor to already labeled occupancies?  For example, I have rooms that I have identified as and Occupancy of 'A2- Assembly'.  I want to identify the Occupant Load Factor of 1 person/15sf to that Occupancy type.  Then my Occupant Load field will calculated the value between area/occupant load factor to give me the total number of occupants in the room.  So, I just want to know how to create the Occupant Load Factor parameter.
Thu, Oct 13, 2011 at 8:34:49 PM | occupant load factor
brandino
Also, does it have anything to do with creating a Key Schedule?  I took a webinar class about this, and I have notes about a Key Schedule.
Fri, Oct 14, 2011 at 6:54:12 AM | occupant load factor
3.5 Stars: 395 Votes
You could add a project parameter to rooms - occupant load - and then have a key schedule that assigns occupant load based on the occupancy field.
Fri, Oct 14, 2011 at 10:31:08 AM | occupant load factor
brandino
How do you create a key schedule and how do you link it to the other schedule?
Occupant Load Factor Tag
Thu, Feb 10, 2011 at 8:34:42 AM
Calculating occupant loads using room schedule
Wed, Mar 7, 2007 at 4:45:12 AM
Room schedules and keynoting?
Wed, Jun 4, 2008 at 6:45:01 PM
Room Tag with Occupant Load
Thu, Feb 5, 2009 at 1:58:51 PM
room tag with occupancy info (2019)
Thu, Jan 24, 2019 at 9:23:31 AM
Page generation time: 4.6980
