52 Users Online (51 Members):
Forums >> General Discussion >> Revit Project Management >> Creating a Surface Image on Concrete
1 Posts No Rating |
Hey,
Ive only started using Revit and I want to create a surface image on Concrete. Specifically I want leaves on the surface of the concrete, that are discernible. I tried using a bitmap but it just looks awkward and nothing like what I want. Any advice!!???
I'm a little desperate here, presentation is soon and I'm stuck!
![mbsteve Avatar](user_avatar/23553.jpg)
![4 Stars: 13 Votes](/images/stars_4.gif) |
when you say you tried a bit map, do you mean you took a picture and tried to place it as a decal? try CGtextures.com. they may have something that you can add to the concrete surface. however it will be a repeat pattern if you are looking for autumn leaves, or something like that a decal would be the closest probably.
Creating a topographic surface from image |
Thu, Mar 5, 2009 at 1:44:38 PM
Creating Topo using an image |
Mon, Feb 21, 2011 at 2:18:32 PM
Creating Folded steel plate stair with concrete tread |
Wed, Sep 5, 2012 at 1:07:47 PM
Image over Topo Surface |
Thu, Oct 2, 2008 at 7:56:15 PM
Concrete control joints |
Thu, Mar 31, 2016 at 1:52:27 PM
11
Members: | 2022285 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
