Forums >> Community >> Newbies >> Exporting Sheets as image for printing.
87 Posts No Rating |
if I export my sheets as images at 100%, does it print to scale if I send it to the printers? Has anyone done this before?
No... print your sheets to PDF for a better effect.
My image saved at 2600 pixels at screen resolution, AKA 92 DPI.
Edited on: Thu, Oct 13, 2011 at 1:33:42 PM
if I export my sheets as images at 100%, does it print to scale if I send it to the printers? "
if your sheet is 11x17- and you export that sheet/image at 100%- it will fit perfect on the 11x17 paper you print it to.. as for scale on paper- it will print the scale you have on the sheet..
that pixelation you are showing us won't happen if you export the image at 10,000 pixels and then resize the image for printing or viewing..
I know, but there's an option in export images of "zooming" to 100% instead of fitting to an arbitrary pixel number, and I was pointing out that zooming to 100% will give an awful result.
set it at 100% and turn the "raster image quality" all the way up.. no awful results then.. what am i missing?
ego- actually you are more right than wrong.. even if you do turn up the raster quality it's really no longer exporting 100%..
Print at Scale via Jpeg |
Fri, Jun 27, 2014 at 1:07:04 PM
Questions about printing/exporting to PDF |
Sun, Aug 31, 2014 at 7:32:57 PM
Fill Region set to Transparent but printing Opaque [ 1 2 ] |
Sat, Jan 26, 2019 at 12:16:16 AM
17
printing sheet sets - only the sheets |
Wed, Jul 18, 2012 at 3:10:11 PM
Error printing after printing 5 of 7 sheets. |
Wed, Feb 20, 2008 at 2:12:38 PM
Members: | 2115062 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
