54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Aligned dimensions for centering curtain wall door
21 Posts No Rating |
I have been frustrated by this for a while: is there a way to use the aligned dimensions to tell revit to place vertical curtain panel lines equal distances from the walls (I don't care what distance, as long as its equal) but center a 2m opening? I know how to use aligned dimensions to make all three lines equidistant...but I only want the outer two equidistant while maintaining the interior dimension. See picture if that makes no sense. Thanks.
Lock your center dim. Then place a dimension from the left to the center of your center panlel then to the right and set that to EQ. Then middle section will move to the center. ...delete the EQ dimension string.
Brilliant. Thank you!
1 Posts No Rating |
HI, IM FACING A SIMILAR PROBLEM. CAN SOMEBODY PLEASE HELP HOW CAN I KEEP THE INTERNAL DIMENSIONS ALL EQUAL. I HAVE CIRCLED THE END DIMENSIONS (4'-3") WHICH ARE DIFFERENT FROM THE REST. PLEASE HAVE A LOOK AT THE ATTACHED PICTURE.
Add a string of dimensions that are to the center of the mullions. The grid. At the ends, it would be to a line since you have no grid line. No hit your equal switch. BTW - Unless you really have different mullions, it is better to dimension to centerline anyway.
Curtain Wall sliding door family not centering |
Mon, Oct 5, 2015 at 6:19:33 PM
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:11 AM
curtain wall door |
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame |
Mon, Mar 2, 2015 at 11:37:33 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012 |
Thu, Jul 7, 2011 at 4:27:10 PM
Members: | 2056236 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
