59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Wall schedule all data is wrong?
Hi,
How can i make a correct wall schedule if revit makes mistakes like this all over the place?
disallow join could fix this but seriously? there has to be a better way?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
What mistake? How does Revit know where you think it should measure a wall? It could be inside dimension - outside dimension, what? Revit always measures centerline of joining wall to centerline of joining wall.
yes i can see that, but revit also seems to know where i want my wall to stop as drawn in planview.
any advise on workarounds or best practises for scheduling correct wall volumes and areas?
peace is the path."
Mahatma Gandhi.
Revit's cleanup at wall joins is based on the function you assign in the wall type layer. That really affects material areas.
Remember, Revit is NOT an estimating program but it can still give you some useful information. You just have to understand all the rules. (I still don't) I suggest you create a very simple project with two walls and do some reporting where you can monitor what happens when. I would vary the function numbers and see how that affects the takeoffs. You may find that material reporting may be more useful in some instances rather than wall.
1 Posts No Rating |
Hi Dafpfy,
Suffering from the same issue. Could you find any workaround?
from/to room data in door schedule of a host model |
Fri, May 15, 2020 at 10:47:42 AM
Family Type Data and the Door Schedule |
Wed, Aug 24, 2011 at 10:25:17 AM
11
Retaining Curtain Wall Door Scheduling Data |
Thu, Jan 8, 2015 at 2:47:08 PM
CANNOT INSERT DATA ROW |
Mon, Jul 4, 2022 at 3:01:56 PM
Schedule will not allow me to add new data row |
Mon, Apr 27, 2015 at 7:53:54 AM
Members: | 2017168 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
