108 Users Online (107 Members):
Forums >> Revit Building >> Technical Support >> Co-ordinate problems - miles out!
12 Posts No Rating |
I have imported an Autocad file with pegs with co-ords
I set the first peg up with specify co-ords, then when i go to annotate the other pegs are MILES out?
I have never heard the term PEG in conjunction with Revit or CAD.
I agree with WW, peg is an interesting term. I will assume that you mean property corners. Usually, most of the survey data that I get is set up as 1" = 1'-0", some of the older programs did this for decimal convienence, perhaps this is your problem. Check to see if the survey data is 1/12th the size. You may have to scale data to get it to fit properly.
Ordinate Dimension Style |
Mon, Sep 19, 2016 at 10:12:14 AM
Slow performance Revit 2014 XenDesktop |
Fri, Oct 17, 2014 at 10:04:30 AM
Importing Autocad background - Revit Model to exceede 2 miles across [ 1 2 ] |
Sat, Apr 17, 2010 at 7:29:52 PM
20
Trying to move Project location in not all revit files |
Wed, Oct 16, 2013 at 10:52:13 AM
lines on topo surface |
Tue, Aug 2, 2011 at 2:07:53 PM
Members: | 2017104 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
