98 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> Wall joins, (corner) and Schedule with wall orientation?
9 Posts No Rating |
Hi Guys and girls.
I have som probs with lines showing in 3d at wall corner joins. Same type same location line and so on. Look ok in plan view but in 3d the interior face line shows. I have fixed it a coubel of times buy delting and or using the corner tool but this time it won’t go away!! And I would like to know what I am doing wrong.
Wall schedules: can I make one with orientation (North, East, southwest ect) I need the info for heat calculation in another program??
Thank’s
Jonas. Student DK.
We need to see an image of your wall join problem. Use a screen capture program like ScreenHunter Free.
Wall schedules have no way of knowing what you might mean as North South .... But you can add a project parameter, wall category, instance based that you fill in with data and show in a schedule.
Walls do not associate with rooms and remember, they can span more than one room.
9 Posts No Rating |
Here is a pic.. thanks for the quick reply..
the wall oriention is for a danish program (rockwool energi design) where the walls orientation is inputede for sun path reason.
thanks.
Try editing the joins and use a miter instead of a but join.
Or use the "Join Geometry" tool
9 Posts No Rating |
FIXed thanks alot.. the mitter worked!
Jonas
Can you make wall joins Miter by Default? |
Wed, Dec 21, 2016 at 1:52:44 PM
14
Corner guards to snap to corner of wall |
Tue, May 13, 2014 at 12:18:44 PM
Dimensioning to angled wall joins |
Wed, Jan 14, 2009 at 6:59:44 PM
Revit 2014 - Disallow wall joins by default |
Tue, Jun 17, 2014 at 10:23:21 AM
wall intersection with curtain wall |
Mon, Apr 14, 2014 at 10:48:38 AM
Members: | 2017318 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
