65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Walkthrough FROM existing 3d views.
1 Posts No Rating |
Hello all,
This is my first post but i have lurked and searched often.
My question is: Can i create a walkthrough using existing 3d views in Revit 2011?
I have a series of views I am using to render from. Each has specific objects hidden and different shadows. I would like to render the images over the weekend.
I know I can render individual Key Frames in a walkthrough, but it is a pain in the curse to set up each Key Frame exactly like the 3d views I already have.
I also know I could set up a Journal file to render my existing 3d views. I have limited code skills, and would prefer to use the built-in settings in Revit like the Walk through.
Revit really just needs a batch rendering code built in.
Thanks for any help!
![itsmyalterego Avatar](user_avatar/109615.jpg)
Wellll, You could make a view template from your 3d views, and apply the template to a walkthrough view to give it nearly identical properties. Objects you've hidden -specifically- in the view with overrides to VG will not be applied in a template, but if you've controled visibility by categories and worksets and such, you'll be good to go.
Converting Walkthrough to Individual Views |
Tue, Feb 7, 2012 at 4:40:37 PM
animation / walkthrough |
Thu, Nov 11, 2004 at 3:27:00 PM
Cameras into a walkthrough |
Fri, Apr 3, 2015 at 1:20:27 PM
Multi Level Walkthrough Help |
Sat, Jan 8, 2011 at 6:14:10 AM
Exporting Walkthrough Trouble |
Thu, Apr 17, 2008 at 8:00:50 AM
Members: | 2017463 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
