54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Model roof framing using Ref Planes Vs. Levels with start/end offsets
Wed, Oct 5, 2011 at 2:15:46 PM | Model roof framing using Ref Planes Vs. Levels with start/end offsets
jnovella1520
Hey everyone,
I wanted to see what the norm is for modeling the structural roof members in a Revit Structural project.  Currently I model using a specific level for a roof plan (Ex: Level 3 Roof) and use the framing members Start & End Offsets to get the desired slope.  This also works well because the analytical model connects correctly for the most part and there is not much adjustment needed.  However, it can become time consuming everytime the architects change the slope of the roof.  You have to recalculate all the new elevations and adjust the framing members to that height.  There are tools in the newer Revit that help make this easier, but wanted to see if there is a quicker method thats as accurate and able to export.
The other method, which I'm not very famiiar with, is setting up a roof with Reference Planes and attaching the framing members to it.  I've noticed that it's not as accurate, and theres more to adjust in the analytical to get it to export correctly.  Also, when ever I change the slope of the Reference Plane, the framing members will offset fromt the grid and I find myself putting in as much time re-aligning everything as I did recalculating elevations.  Is there a way to lock them in place so they don't detach?  This method seems like it could be easier and quicker to manage the roof plan if it changes slopes, but I can't get it to work very good.  I was just wondering if I am doing something wrong, or if this method has flaws that you have to deal with?
Thanks for the help!
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:38 AM
Conical Roof Framing
Fri, Feb 22, 2013 at 6:07:13 PM
Moving framing members from one Work Plane to another
Wed, Jan 25, 2012 at 3:36:05 PM
11
problems with reference planes when creating a mass
Sat, Oct 16, 2010 at 11:28:47 AM
External Wooden framing family created in Revit 2014 through elevation profile
Thu, Jan 9, 2014 at 2:08:24 PM
Page generation time: 2.1992
