46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Object Styles
Fri, Dec 2, 2005 at 12:39:11 PM | Object Styles Problem
arccodex1
3 Stars: 1 Votes
I've attached a file that demonstrates a problem I'm having. I've imported a DWG file into Revit and I'm trying to change the Object Styles of the lines. Some lines work and others dont. You will see that I've changed the lineweight to 10 for two layers. Only the BUILDG_ layer works. Maybe someone can explain to me why the width of the DRIVEWAY layer won't change. Post edited on 2005-12-02 12:50:32
Fri, Dec 2, 2005 at 1:13:44 PM | RE: Object Styles
arccodex1
3 Stars: 1 Votes
Here's the DWG file.
Fri, Dec 2, 2005 at 4:03:20 PM | RE: Object Styles
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Without looking at the files i'm guessing because that particular line isn't set to BY LAYER...?
Fri, Dec 2, 2005 at 5:31:05 PM | RE: Object Styles
arccodex1
3 Stars: 1 Votes
That's right it's set to "BY OBJECT" how do I alter this setting?
Fri, Dec 2, 2005 at 8:22:30 PM | RE: Object Styles
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Open the DWG and edit in AutoCAD and change to BY LAYER?
Change Default Family Category Model Object Styles
Thu, Jun 18, 2009 at 4:23:46 PM
Object Styles: not implementing
Tue, Jun 1, 2010 at 11:50:14 AM
Object Styles-Can't find where to change cut lines on sweeps--------------------
Mon, Sep 29, 2008 at 4:54:04 PM
Wall Object Styles
Tue, Mar 7, 2006 at 11:29:57 AM
lines styles not printing or displaying
Thu, Jul 17, 2014 at 8:50:31 AM
Page generation time: 0.9569
