100 Users Online (98 Members):
Forums >> Revit Building >> Technical Support >> Roof line
208 Posts No Rating |
Hi all,
Is there a way to show the roof outline on the ground floor plan without drawing each line in?
cadjockey
15 Posts No Rating |
You can click on view properties on your ground floor and select underlay and choose whatever plan your roof is in, this will show you the roof line.
Enran
![latemore Avatar](user_avatar/6368.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
the underlay method is not entirely foolproof we find, especially with rooves. another trick is to cheat a bit and adjust the view range briefly, draw your linework, and readjust view range. watch for any plan regions you may have though.
hope that helps - i think there was a long thread on this a couple of months ago too.
Thanks guys,
I thought this was the case. I was hoping there was a wiz bang setting I could use which meant I could avoid drawing individual lines.
cadjockey
Roof line not showing! |
Wed, Jul 19, 2017 at 7:16:01 AM
Line weights to roof |
Mon, Dec 5, 2005 at 8:30:49 PM
bottom edge of roof line weight |
Thu, Jul 12, 2018 at 9:28:31 AM
Wall Sweep/Siding up to Roof Line |
Fri, Nov 23, 2007 at 11:09:49 AM
Roof Cuts? |
Tue, Oct 24, 2006 at 3:17:47 PM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
